Viktor_k83 Posted January 27 Report Posted January 27 If I have a PLC and I need to submit XX different topics with several variables (say MachineA_state, MachineA_count, MachineB_state, MachineB_count etc.) Publishing is set to be done every 30s. I can either: - call the Pub_Function X times for every machine with its own topic and values. The instances, I guess, must be separated by MQTT.Busy flag or something else to make sure the previous publishing has finished. - modify the Function block to handle XX parameters and call it with the parameters from the main program. The problem is there could be 8-16-32 parameters. What is usually a good practice as I'm just starting with MQTT. Also, if you can tune your message based on Siemens/TIA and Omron/SYSMAC perspective. Have to work on both.
