ipul28 Posted January 29 Report Posted January 29 Hello... Does anyone have experience using me csvdata log ActiveX in FTV Studio? what is the condition of this csvdata log ActiveX creating a new file? is it that when the hmi loses power, and after power returns, active X will create a new data log file? When I tested to turning off the power and turning it on again, there were two log data files created. from the time data, the first file was before the power off, and the second file after the power back. and the problem was in the first file, when I checked it with data tamper software, the results didn't pass. After I opened the file, the last line in the file was not recorded properly/stopped halfway. Thanks Quote
