Risman Posted February 13 Report Posted February 13 Hello guys , if are you have experiance to set up modbus rtu can read & write multiple address please share the tips because i has completed read & write but its only works read single address if use multiple address my program is not working please give me advice for it thanks Quote
Solution BobB Posted February 13 Solution Report Posted February 13 (edited) Easy to use Modbus RTU Master for CP1L CP1H CJ1 CJ2 CS1 - PLC Sample Code - MrPLC.com, in the download section. Edited February 13 by BobB Quote
IO_Rack Posted February 13 Report Posted February 13 https://mrplc.com/files/file/867-easy-to-use-modbus-rtu-master-for-cp1l-cp1h-cj1-cj2-cs1/ Quote
Risman Posted February 13 Author Report Posted February 13 5 minutes ago, IO_Rack said: https://mrplc.com/files/file/867-easy-to-use-modbus-rtu-master-for-cp1l-cp1h-cj1-cj2-cs1/ Thanks you i will try it Quote
