Tevi Posted February 14 Report Posted February 14 Käytän ohjelmointiohjelmia CX-programmer ja EB800. Nyt "opettelen" miten Weintek-näyttö ja Omron- logiikka saadaan keskustelemaan keskenään, mutta homma ei vaan meinaa selvitä. Näytön ohjelma kääntyy ok, ja download menee ok ja liikenne alkaa jotenkin toimimaan (EasyDignoser näyttää, että jotain systeemi-liikennetta kulkee), mutta tag-liikenne ei toimi. Joko näyttö lähettää tagin väärällä tavalla tai logiikka vastaa niin, ettei näyttö ymmärrä. Siis, löytyykö jostakin esimerkki ohjelma jossa tämä toimii tai linkki oppaaseen jossa tätä ongelmaa on selvitetty. Quote
IO_Rack Posted February 14 Report Posted February 14 3 hours ago, Tevi said: I use the programming programs CX-programmer and EB800. Now I'm "learning" how to get the Weintek display and Omron logic to talk to each other, but it's just not going to work out. The program on the screen turns ok, and the download goes ok and the traffic somehow starts working (EasyDignoser shows that some system traffic is passing), but the tag traffic does not work. Either the display sends the tag in the wrong way, or the logic responds so that the screen does not understand. So, is there an example of a program where this works or a link to a guide that explains this problem? https://mrplc.com/forums/topic/44893-connect-omron-cp1l-to-maple-hmi-by-cp1w-cif01/#comment-200874 This gentleman is having a similar issue although he doesn't have a connection. I posted this link because he has included some information that may be helpful to you. Your problem seems to be addressing. Are you sure you are using the correct syntax? What model PLC are you using? What physical port are you connected to? Which Weintek driver are you using? Quote
Tevi Posted February 15 Author Report Posted February 15 Minun PLC on OMRON CJ1M-CPU12 / ETN11. Quote
Tevi Posted February 15 Author Report Posted February 15 Minun PLC OMRON CJ1M-CPU12 / ETN11:ssä. Siis minä yritän saada Ethernet-liikenteen toimimaan PLC:n ja HMI:n välillä. PLC on siis OMRON CJ1M-CPU12 / ETN11 ja HMI on Weintek MT8070iH. Quote
