TH_VN Posted February 14 Report Posted February 14 Hi team ! I have trouble with my Sysmac studio , can you help me to change the display data type when online monitor from Hex to Dec . Thanks and have a nice day. Quote
Solution IO_Rack Posted February 14 Solution Report Posted February 14 This depends on what you wish to do with the value. If you want to "Only View" as a Decimal, open the watch window and change the Display Format. If you wish to use this value as a Decimal in your program, then perform a conversion using WORD_TO_INT or WORD_TO_DINT instruction. 1 Quote
Crossbow Posted February 14 Report Posted February 14 WORD data type will show as hex by default. As IO_Rack said, watch windows can select a display format. INT data type displays decimal. Are you sure you have to use the WORD data type? 1 Quote
TH_VN Posted February 17 Author Report Posted February 17 🤩 Thanks for save me, Actualy the data I take from Ethernet IP Devices so need to keep it by word. Thanks so much Quote
