I don't have Sysmac Studio in front of me right now but I've done X and Y movement before.
Select the line then click the Animations tab. If you don't see it, select Animations from the View menu. I don't know if it has a Rotation property but you can take a look.
If this is too complicated, you can create several lines in different positions then cycle through the visibility of each line.
Sorry I did not follow up on this thread.
The Line object has a Rotate function in the Animations tab. Set an Integer tag, then increase or decrease the value between 0 and 359.
