Swissi Posted April 5 Report Posted April 5 Hi I have problem, I can't install Tia portal on pc windows 10 , it was installed before and running normal. Now it shows error after fishing installation , please check attached photo of the error shown. I really appreciate your help Regards
Hati Posted April 5 Report Posted April 5 V13 SP2 is needed for Win10. Installation log will tell you more info.
Swissi Posted April 6 Author Report Posted April 6 Hi Sorry I wasn't clear. Every time I install it, it fails and show this error message in installation log. It says file not found. Please check attached photo, message is in red circle, I searched in chrome but couldn't find clear answer for the error message meaning. Is it fault with windows or tia portal files? Thanks in advance
Hati Posted April 6 Report Posted April 6 (edited) That picture doesn't give any info. What version of TIA13 were you trying to install? Win10 needs V13 SP2. What version of Win10 do you have? Edited April 6 by Hati
Swissi Posted April 6 Author Report Posted April 6 Trying ti install Tia v13 sp1, then will install Sp2. As per instructions in the website i downloded tia portal from. Please check this link https://plc4me.com/download-tia-portal_v13_sp2-win-1087-real-100/ Please check attached photo of installation instructions on windows10. Photo is screenshot of instructions from same website .
Swissi Posted April 6 Author Report Posted April 6 windows 10 pro, version 22H2, (OS build 19045.5679)
Solution Hati Posted April 7 Solution Report Posted April 7 You should download the v13 SP2 installation files from Siemens site. When you download installation packages from somewhere else, you get these unexpected errors. SIMATIC STEP 7 including PLCSIM V13 SP2 TRIAL Download
