48 minutes ago, chakka said:
Mc_home으로 가라고 클릭을 하면 5441이 뜨면서 에러가 발생을 하는데 왜 그럴까
Translation:
Quote
When I click to go to Mc_home, an error occurs with 5441 appearing. Why is that?
I do not see that error code in the troubleshooting manual.
Try extracting the ErrorID from the MC_HomeWithParameter instruction. The ErrorID should be referenced in the NJ/NX-series Troubleshooting Manual (W503).
Edit:  I found the error code in the above manual. Make sure _EC_PDSlavTbl[x] bit is ON before performing MC_HomeWithParameters. (x = the EtherCAT node of your servo).
I also check that _EC_CommErrTbl[x] is NOT ON.
Are you saying that I should use MC_HomeWithParameter?
The servo is ON. Even if I send it to home and an error occurs, the servo remains ON.
According to the manual, I checked and _EC_PDSlavTbl[x] is also ON.
Edited by chakka
No, not necessarily. I saw it in your error message. I cannot read the remainder.
How are you attempting to establish Home?
Does the Axis > Homing Settings match your method?
Pretty sure 5441 is related to an end of travel limit.  I would check the manual and see for sure, I don't have it handy.
