RJ65BT11+16 Remote Stations
Go to solution Solved by Gambit,
Hello!
I have R04CPU with RJ65BT11. There is Parameter Setting Method in GX Works3 Module Parameter for RJ65BT11. In Explanation: "Up to 8 modules can be set by 'Parameter Editor' per 1 CPU module. If you want to set 8 or more modules, please set it by 'Program'." We need to use RJ65BT11 with 16 Remote station. I know how setup them in Parameter Editor, but don't know how setup Link Refresh via Program.  Will the setting work via the Parameter editor for 16 remote modules???? I have only 2 remote modules on my table for test and can't test setup with 16 before mounting on equipment.
Yes, rj61bt11. Remote station is AJ65SBTB1, so I mixed up. This is written in the explanation when choosing Setting Method of Basic/Application Settings.
Edited by Jolly
  • Solution
haha i think they mean 8 RJ61 modules not the remote I/O.. That makes sense it was the same with the system Q
