LucasBorges Posted July 23 Report Posted July 23 Hi everyone, I’m having trouble connecting to a Magelis HMISTO532 panel using EcoStruxure Machine Expert - Basic. Here’s what I’ve tried so far: Panel status: The HMI shows the message: “Cannot Load Runtime - Waiting for connection…” It’s in download mode, powered on and functional. Connection attempts: I’ve tried mini-USB and Ethernet. Disabled WiFi to avoid IP conflicts. Ran Advanced IP Scanner and found the HMI at IP: 10.10.139.158. However, it does not show up in the commissioning interface of EcoStruxure. I’ve changed connection ports, but it still doesn’t work. Questions: What port should I connect to exactly? Do I need to install the Runtime using Vijeo Designer before using EcoStruxure? Is this panel (HMISTO532) even compatible with EcoStruxure Machine Expert - Basic? 📸 I’ve attached photos of the device and its label. Thanks in advance! — Lucas
Solution acpi Posted July 23 Solution Report Posted July 23 Hi, You can use Ethernet port either to transfer the Vijeo Designer application or communicate with the M221. Installation of the runtime is done automatically when you transfer the applicationh from Vijeo Designer. Your HMI is compatible with M221 plc programmed with Machine Expert Basic. I recomend to wath this video that explain step by step how to proceed : JC 1
