I'm trying to add a second QJ71E71 card to a Q Series PLC.   Based off of instructions I've read online I need to go to PLC parameter and add there under I/O assignment and then go to ether net under network parameter to set the module up.  However, when I try to add a second network type of ethernet in module 2 I receive the error "The number of Ethernet is up to 1."
Which CPU model are you using?  There may be a limit on that module for that CPU type.  Check the hardware manual for the Ethernet module.
