Nik123 Posted August 7 Report Posted August 7 (edited) I'm working with a Mitsubishi FX5UC-32MT/DSS-TS PLC and trying to read data from multiple D registers using the MC protocol, specifically the 0406 command (QnA-compatible 3E frame for multiple-block batch read). Currently, I can successfully read one register at a time using command 0401, but I want to optimize this by reading multiple blocks in a single request. I followed a YouTube tutorial (https://www.youtube.com/watch?v=El1h99SCKns) and implemented the code in VB.NET. I also reviewed the MELSEC Communication Protocol manual, but I’m having trouble understanding how to correctly structure the binary frame for 0406. Private Sub MultiReadDataRegister(rdAddressTextBox As TextBox, disTextBox As TextBox, rdValue As TextBox) Dim DeviceNo_D As String Dim DeviceNo2_D As String Dim DeviceNo15_D As String Dim DeviceNo16_D As String Dim DeviceNo17_D As String DeviceNo_D = rdAddressTextBox.Text If String.IsNullOrWhiteSpace(DeviceNo_D) OrElse Val(DeviceNo_D) < 0 Then rdAddressTextBox.Text = "0" Else DeviceNo_D = rdAddressTextBox.Text End If DeviceNo_D = rdAddressTextBox.Text DeviceNo2_D = Hex(DeviceNo_D).PadLeft(6, "0").Substring(0, 6) DeviceNo15_D = DeviceNo2_D.Substring(4, 2) DeviceNo16_D = DeviceNo2_D.Substring(2, 2) DeviceNo17_D = DeviceNo2_D.Substring(0, 2) Dim sendmessage4(22) As String 'Binary Code sendmessage4(0) = "50" 'Subheader - Set the fixed value (request message: '5000', response message: 'D000') sendmessage4(1) = "00" 'Subheader - Set the fixed value (request message: '5000', response message: 'D000') sendmessage4(2) = "00" 'NetWork No. sendmessage4(3) = "FF" 'Pc No. sendmessage4(4) = "FF" 'Request destination module I/O No. sendmessage4(5) = "03" 'Request destination module I/O No. sendmessage4(6) = "00" 'Request destination Module station No sendmessage4(7) = "0C" 'Requested Data Length sendmessage4(8) = "00" 'Requested Data Length sendmessage4(9) = "10" 'Monitoring timer sendmessage4(10) = "00" 'Monitoring timer sendmessage4(11) = "06" 'Command sendmessage4(12) = "04" 'Command sendmessage4(13) = "00" 'SubCommand sendmessage4(14) = "00" 'SubCommand sendmessage4(15) = "02" 'Number of word device blocks sendmessage4(16) = "00" 'Number of bit device blocks sendmessage4(17) = DeviceNo15_D sendmessage4(18) = DeviceNo16_D sendmessage4(19) = DeviceNo17_D sendmessage4(20) = "A8" 'Device Code in Hexadecimal format. It indecate Data register D^* sendmessage4(21) = "02" 'Number of Device Points to Read - Low byte Example: user input is D200 so it implies 3 consecutive device points, possibly D200,D201,D202 'sendmessage4(22) = "00" 'Number of Device Points to Read - High byte 'Socket connected then it send And recive the message If _socket.Connected Then Dim bytereceiveMessage4 = SendAndReceive(sendmessage4) If bytereceiveMessage4 IsNot Nothing Then Dim arrays As Byte() = {bytereceiveMessage4(11), bytereceiveMessage4(12)} rdValue.Text = BitConverter.ToUInt16(arrays, 0) If rdValue.Text = 0 Then rdValue.BackColor = Color.Blue rdValue.ForeColor = Color.White Else rdValue.BackColor = Color.White rdValue.ForeColor = Color.Black End If disTextBox.Text = rdValue.Text / 10 End If End If End Sub Private Function SendAndReceive(sendMessage As String()) As Byte() Dim byteSendMessage As Byte() = StringsToBytes(sendMessage) _socket.Send(byteSendMessage, byteSendMessage.GetLength(0), SocketFlags.None) Dim byteReceiveMessage As Byte() Dim ReceiveSize As Integer = 0 Do byteReceiveMessage = New Byte(_socket.Available - 1) {} ReceiveSize = _socket.Receive(byteReceiveMessage, byteReceiveMessage.GetLength(0), SocketFlags.None) Loop While ReceiveSize = 0 Return byteReceiveMessage End Function Private Function StringsToBytes(src() As String) As Byte() Dim returnBytes(src.Length - 1) As Byte Dim i As Integer For i = 0 To src.Length - 1 returnBytes(i) = Convert.ToByte(src(i), 16) Next Return returnBytes End Function What I tried: I implemented a VB.NET socket communication routine based on a YouTube tutorial to send a 3E frame using command 0406 (multiple-block batch read). I constructed the binary frame manually, including the subheader, network and station numbers, command code, and device address formatting. I verified that the PLC is in RUN mode, and that MC protocol communication is enabled. I tested the same setup using command 0401 for single-block batch read, and it worked correctly — I was able to read one D register at a time. What I expected: I expected the PLC to return data for multiple D registers (e.g., D200, D201, D202) in a single response frame when using command 0406. I anticipated that the response would contain the values of all requested registers, allowing me to parse and display them efficiently. What actually happened: In some cases, the socket received a frame, but its not a actual value. sometimes socket received this 0 - 208 1 - 0 2 - 0 3 - 255 4 - 255 5 - 3 6 - 0 7 - 11 8 - 0 9 - 97 10 - 192 11 - 0 12 - 255 13 - 255 14 - 3 15 - 0 16 - 6 17 - 4 18 - 0 19 - 0 I suspect the issue may be due to incorrect frame formatting. Edited August 7 by Nik123
SergeyBorchshev Posted August 8 Report Posted August 8 Hello, it seems your message format is incorrect. It was a discussion on this forum some time ago, but we were talking about Q03UDE PLC. I do not have a manual for FX5UC MC protocol, but will look in to it. But here is a link for MC protocol libraries, hope this will help. https://github.com/YudaiKitamura/McpX
SergeyBorchshev Posted August 8 Report Posted August 8 (edited) Also what is the reason to read blocks with 0406 command? You ca read a range on devices with 0401. IF in binary - 0x50, 0x00, # Subheader (2B) 0x00, 0xFF, # Network Number & PLC Number (2B) 0x0C, 0x00, # Request Length (2B) 0x01, 0x04, # Command Code (Read Word Device - 0x0401) 0x00, 0x00, # Subcommand (2B) 0x2E, 0xE1, 0x00, # Start Address (D12001 - 3B) 0xA8, #Device code (D in binary message is A8 - 1B) 0x06, 0x00 # Number of Points to Read (2B) This message should read 6 words starting from D12001. Or this will read 10 points from starting D0 0x50, 0x00, // Sub Header 0x00, 0xFF, 0xFF, 0x03, 0x00, // Route 0x0C, 0x00, // Request Length 0x00, 0x00, // Monitoring Timer 0x01, 0x04, 0x00, 0x00, // Command 0x00, 0x00, 0x00, // Device Address 0xA8, // Device Prefix 0x10, 0x00 // Device Length the only reason for 0406 is you can read bits and words in the same message, or blocks of words/bits that are not consecutive. Personally never tried... Edited August 8 by SergeyBorchshev Addition
Nik123 Posted August 12 Author Report Posted August 12 Thank you Sergey Borchshev, I see that open-source library, but it didn't support the command 0406 and I just got the email from Mitsubishi that I am using the wrong message format. I need to use 3C Format to utilize the 0406 command. I changed the format, but I am still getting the issue but diffrent one.
Mark- Posted August 12 Report Posted August 12 OK, the manual, page 3-122 or 3-123 has a complete example. If you try to read the same data, does your code produce the same request frame?
Nik123 Posted August 12 Author Report Posted August 12 (edited) Hi Mark, The link you mention of PeakHMI is not working. Are you talking about these manuals ? MELSEC Communication Protocol jy997d60801g.pdf Edited August 12 by Nik123
Mark- Posted August 12 Report Posted August 12 Thanks. Not sure what is going on with the link, I changed the link in the signature. This one works http://www.hmisys.com/ Attached is the manual I was using to look at the command. Q Protocol Spec 2 .pdf
SergeyBorchshev Posted August 13 Report Posted August 13 (edited) I think you referencing to a wrong manual. Here is the one you need for FX5UC. Check part 6 MC protocol. It definitely asking for 3C frame... https://dl.mitsubishielectric.com/dl/fa/document/manual/plcf/sh082625eng/sh082625engf.pdf Could not upload whole file, here is Part 6 only FX5UC part 6 comm manual.pdf Edited August 13 by SergeyBorchshev
SergeyBorchshev Posted August 13 Report Posted August 13 For 3C on FX5U format should be in ASCII not binary
