LordVilla Posted August 14 Report Posted August 14 Hi. Can anyone shed any light on this, please: I have a project in GXWorks 1.060N and GX Configurator PN. Recently I bought a new laptop and installed GXWorks 1.110Q. When I open the project, the PLC code and configuration is fine, but there are no Profinet configurations. I have tried uploading the whole project (code and parameters) but still get nothing. Thank you.
Crossbow Posted August 14 Report Posted August 14 Never touched the Profinet module, but I know with the Ethernet IP module it saves to a separate file, not part of the GX Works project.
VeeB Posted August 14 Report Posted August 14 On your new laptop you need to install separately the GX Configurator PN software. After installation it will be available in GXW3 again. (restart is necessary) 1
Solution LordVilla Posted August 29 Author Solution Report Posted August 29 Thank you for your answers. After installing GX Configurator PN, I copied the directories:- GSDML & XSD They are located in ProgramData > MELSOFT > GX Configurator-PN 2.00 > GSDML Library All the configuration appeared. Happy ending.
