malek ch Posted October 14 Report Posted October 14 Hello everyone, I’m currently working on my final-year industrial project, which involves controlling a gantry system with 4 axes using Siemens TIA Portal (Motion Control). The system includes two motors driving the same Y-axis (Y1 and Y2), in addition to X and Z axes. For the Y-axis, I used the MC_GearIn block to synchronize Y2 with Y1 (or a virtual master). However, I noticed that MC_GearIn only synchronizes position and velocity — it does not compensate for mechanical misalignment (skew) between the two sides of the gantry. So my questions are: Is it reliable to use MC_GearIn for a gantry system in an industrial setup? How can I compensate or correct the skew error between Y1 and Y2? Should I consider a “Gantry Control” function block or a custom feedback correction loop (position difference feedback)? Any advice, practical examples, or experience sharing would be really appreciated. Thank you in advance! Khalifa C.
jrw Posted October 14 Report Posted October 14 Do you have a picture ? these are independent motors and are not mechanical linked together right? ie with a shaft
malek ch Posted October 15 Author Report Posted October 15 i have 3d picture : Yes, the two motors are independent and not mechanically linked together.
Hati Posted October 15 Report Posted October 15 Both motors have a encoder feedback? Then it should be no problem to drive them with MC_Gear. That block is made for this kind of gearing.
malek ch Posted October 23 Author Report Posted October 23 yes both motors have encoder feedback , thank you very much
