Josue Badillo Posted October 28 Report Posted October 28 (edited) Estoy tratando de conectar Un PLC FX5U con un atornillador INGERSOLL, dicho atornillador solo tiene habilitados ciertos protocolos que no son compatibles con Mitsubishi (Ethernet/IP), para eso uso el ENET/IP, para poder leer los registros del atornillador De un principio pude hacer la conexion muy trasnparente, no es muy complicado, solo que de un dia a otro perdio la conexion y ya trate de reiniciar todo, atornillador, Plc, Modulos, restableci y cambie Ip´s y nada, no puedo hacer que se vuelvan a conectar Alguien ha tenido un problema como este? Anexo imagenes de los programas Con la confirguracion actual logre la comunicacion e incluso estuvo funcionando por mas de 2 semanas asi sin problemas Los errores de codigo que muestra en el GXWorks3 los trate de buscar en el PDF de ayuda del ENET/IP pero no aparece nada similar Saludos desde MX. Edit: I am trying to connect an FX5U PLC with an INGERSOLL [screwdriver ???]. This screwdriver only has certain protocols enabled that are not compatible with Mitsubishi (Ethernet/IP). For this, I am using ENET/IP to be able to read the screwdriver's registers. At first, I was able to make the connection very smoothly; it is not very complicated. However, from one day to the next, it lost the connection. I have already tried restarting everything—screwdriver, PLC, modules—I reset and changed the IPs, but nothing worked; I cannot get them to reconnect.Has anyone had a problem like this?I am attaching images of the programs. With the current configuration, I was able to establish communication and it even worked for more than 2 weeks without any issues.The error codes that appear in GXWorks3, I tried to look them up in the ENET/IP help PDF, but nothing similar appeared.Greetings from MX. Edited October 28 by Mark- Translate
