I downloaded the JIC menu from hear. I am very new to cad and was wondering is it possible to change the color of the symbols and text? I have tried a couple of things but I really have no clue. Thanx Matt
Just open each DWG file up in the C:/CAD folder into autocad. Then EXPLODE the drawing. Once exploded, you can change the colors etc.. You probablly want to WBLOCK the drawing once finished. I am not sure if you can edit a layer when a drawing is a block. ATTEDIT only edits text attributes within the block, not block properties that I know of....
I work with Autocad almost every day, you can customize the blocks, by opening the individual block drawings. When opened this way, instead of insterting, you can edit all the colors, attributes, etc... You do not need to explode it, and you do not have to Wblock it, just save it back to it's original location. If you are working in a drawing and insert one of the blocks, you can change the colors by using the "refedit" command. This will alter all instances of the block in that drawing only. Also if you change the colors and want to update an existing drawing, open that drawing, insert the "new" block from your hard drive, not from within the drawing, you will be prompted to update the block definition, say yes, all the existing blocks will be updated. Ken The above instructions work with Autocad, but I do not know about Lite, never used Lite.
Thanks for the help fellas. It worked like a charm without exploding it. I would love to get Autocad electrical but the company I work for is a little cheap and we basically just update equipment and reuse equipment so we have most of the drawings and just need to redo them.
