GerryB55 Posted June 17, 2005 Report Posted June 17, 2005 I'm working on a spreadsheet to estimate costs. In the past I have used a 'best guess' for estimating the actual PLC and HMI programming times. Does anyone have any ideas, or know where I might get some, on estimating times based on I/O count, number of modules, tags, number of screens etc? Any ideas gratfully recieved. Thanks in advance
Chris Elston Posted June 17, 2005 Report Posted June 17, 2005 I use a rule "1 hour per I/O point". That seems to get me pretty close. Also you can use this spread sheet too. I think you'll like it. It uses minutes to calculate operations. plc_estimate.xlt
TConnolly Posted June 24, 2005 Report Posted June 24, 2005 Excellent spreadsheet Chakorules. I use 8 hrs per page for electrical drawings + 1 day. I use a parametric build utility to generate the rough drawing from a spreadsheet, then I detail it. Double the time when its an IEC drawing. Each specialty symbol on the drawings adds 2 hours to the estimate. For programming: I use 1 day/discrete IO card upto 16 points, 2 days for 32 point cards. Analog entirely depends upon the application and my own experience. I swag it on the HMI, I haven't really developed a method there except to rely on my experience, sometime I take a bath on those. 1
PdL Posted June 24, 2005 Report Posted June 24, 2005 Whatever you estimate on hours, if you think you got it all - multiply times 2. In the end it proves to work out that way.
gravitar Posted June 24, 2005 Report Posted June 24, 2005 I've found that this formula works well on estimating materials cost, too :)
LarryE77 Posted June 3, 2017 Report Posted June 3, 2017 On 6/17/2005 at 0:18 PM, Chris Elston said: I use a rule "1 hour per I/O point". That seems to get me pretty close. Also you can use this spread sheet too. I think you'll like it. It uses minutes to calculate operations. plc_estimate.xlt How can I get a copy of the plc_estimate.xlt ?
ControlsGirl Posted December 6, 2024 Report Posted December 6, 2024 On 6/17/2005 at 1:18 PM, Chris Elston said: I use a rule "1 hour per I/O point". That seems to get me pretty close. Also you can use this spread sheet too. I think you'll like it. It uses minutes to calculate operations. plc_estimate.xlt could you share this again?
Chris Elston Posted December 8, 2024 Report Posted December 8, 2024 On 12/6/2024 at 4:19 PM, ControlsGirl said: could you share this again? This thread is 19 years old. LOL. I am not sure if I still have this file. I will check it might take me a few days because I am traveling until Thursday. I'll check though.
Chris Elston Posted December 15, 2024 Report Posted December 15, 2024 @ControlsGirl okay I think this is it? The pricing and data is old. For Allen Bradley, I typically use the Proposal Works software now to get pricing but you can adjust hourly rates here to get an idea on quoting. I hope it helps. plc_estimate.xlt
