maccxim Posted June 24, 2005 Report Posted June 24, 2005 I have to use an old model of FX2 cpu (not FX2N!). Qustion: is possible to install special modules of FX plc, such for example FX2AD/FX2DA/... ? thank you Max Quote
Crossbow Posted June 24, 2005 Report Posted June 24, 2005 Yes. The FX2 should be a drop-in replacement for an FX, so it would use the same extensions. Quote
