bigjoe Posted June 25, 2005 Report Posted June 25, 2005 Can anybody help me, just learning plc then I read about shift register, so I tried making a ladder on medoc this is the only thing that I made and I don't know what's next X11 --l l----------[sFTL X0 M0 K14 K4] So anybody can help me and explain further or give some examples? Quote
mjrx Posted June 25, 2005 Report Posted June 25, 2005 There is a good explanation in the articles section. http://www.mrplc.com/kb/index.php?page=ind...x_v2&id=71&c=12 Also see the FX manual, I think you can download it in the downloads section. Quote
Sergei Troizky Posted June 26, 2005 Report Posted June 26, 2005 Bigjoe, you did not explain the task or the difficulties. Still, read first about the pulse format of the instructions. Quote
bigjoe Posted June 27, 2005 Author Report Posted June 27, 2005 (edited) sergei, actually I am just making an experiment to see how the shift register works and I just saw that pattern of the ladder on the mitsu manual from this site. Base from what I have read shift register theoretically they have a signal for data and clock pulse. So I am asking with the circuit I had wrote before which of those represents the data and clock, is it X11 or X0? and what does the other part of the circuit represents because I am confused? Thanks REgards, johnny Edited June 27, 2005 by bigjoe Quote
vyrdz Posted June 27, 2005 Report Posted June 27, 2005 X11 --l l----------[sFTL X0 M0 K14 K4] Hi Bigjoe, Ladder above implies: X11 is the clock, Please refer to the table below: The cycle will repeat until the K14 is satisfied... Quote
Guest Guest_billy Posted June 28, 2005 Report Posted June 28, 2005 Hi! I am just learning plc also and I am using medoc version 2.4, FXo plc. I just saw this thread about SFTL. I am trying to write also ladder to see how it works, but instead of SFTL, I want to try SFTLP however I could not find that function on Medoc. Does have medoc have that function with FXo? IF it does how? Please site some examples? Quote
maccxim Posted June 28, 2005 Report Posted June 28, 2005 Try to use PLS instruction with an auxiliary M and use it as shift clock input. Max Quote
Sergei Troizky Posted June 29, 2005 Report Posted June 29, 2005 (edited) X11 is not a "clock" actually. It is the instruction execution condition, which execution will be permanent (in every PLC scan) as long as the condition is true. For single execution use pulse as a condition or the instruction pulse format. Edited June 29, 2005 by Sergei Troizky Quote
