maccxim Posted June 28, 2005 Report Posted June 28, 2005 Somebody know the QJ71MT91 Modbus card. I know it provides only TCP Modbus protocol and not RTU. Somebody has a plc program example for using this card? i.e. Master or slave function. Best regards Max Quote
tmu Posted June 28, 2005 Report Posted June 28, 2005 Hi, just wondering: GX IEC Dev or GX-Dev? I would also be interested in... Tmu 158847.pdf Quote
Crossbow Posted June 29, 2005 Report Posted June 29, 2005 The manual is posted on www.meau.com in the Downloads section. There is example code on how to use this module in the manual. I don't have an example program yet because I have not received my module yet. There is a configuration tool (GX-Configurator-MB) that makes configuring the module much easier. Quote
Guest Guest Posted June 30, 2005 Report Posted June 30, 2005 I use GX developer i've seen manual on meau.com thank you Max Quote
