Hi All I have been asked by my boss to work out the max amps on a new panel we are getting.I have all the info on the items in the panel.He wants to know so we can get a mains cable ran in.I do not know if I add all the max amps together or is there another way. Thank you for your time
You definately want to add all of the MAX amps for a total full load rating. That becomes the worst case scenario. Then add 10 to 50% for heat derating. Your local code should be consulted for the exact amount of derating based on length of the cable run.
Guest Guest_Bill
For panels with motor loads you typically take the motor with the largest current draw and multiply it by 125%, then add all of the other motor loads to that for a total (of motors only). Then add in other loads such as transformers, etc.
