STOOP Posted July 7, 2005 Report Posted July 7, 2005 Can any body give me information on how to set up WINCC V5.1 and SIMATIC NET 07/2001 to connect with a S7-200 CPU 224 via a CP5611 comunication. Thanks card Quote
Guest Guest_guest Posted July 9, 2005 Report Posted July 9, 2005 The easiest way is to use Siemens PC Access with WinCC. Use the OPC communication channel with WinCC. It is very easy. What operating system are you using with your older version of SimaticNet??? Quote
Guest Guest_STOOP Posted July 11, 2005 Report Posted July 11, 2005 My operating system is Windows 2000 Quote
