Davecsm Posted July 13, 2005 Report Posted July 13, 2005 Anyone got a program example to write data to this card (List prefered). Got the Mitsubishi manual for it but not having much joy. Thanks, Dave. Quote
Colin Carpenter Posted July 13, 2005 Report Posted July 13, 2005 Please find attached PDF showing one programmed in IEC developer on a Q2AS CPU ..... easy to change. Have you remembered to turn on the Y outputs in order to get the channels to work? 62AD.pdf Quote
Guest Guest_Davecsm Posted July 14, 2005 Report Posted July 14, 2005 That's good, I clicked on add reply and it added it four times. What's that all about then? Quote
panic mode Posted July 14, 2005 Report Posted July 14, 2005 you just need some patience or faster network connection Quote
