Kirby K. Posted July 28, 2005 Report Posted July 28, 2005 Has anyone had problems with the 18i controls getting alarm 1 on the power supply and alarm 30 on the spindle drive when the machine (lathe) is brought out of E-stop? I have called and talked to fanuc about this problem and they keep telling me to change the power supply etc... However, I have 35 (+/-) out of 40 machines doing this at startup (sunday night; I work 3rd shift) and at other times durring the week. I dont see all the machines in the shop having bad power supplys, plus, changing them has not corrected the problem. Incoming power is clean and within spec. Isolation transformer taps and voltage is good. Anyone been here before. Help. Quote
