Guest Bob B Posted August 1, 2005 Report Posted August 1, 2005 Does anybody know if it's possible to use a compact flash/pcmcia card to download the configuration file for a siemens MP370 panel? Slots for both are provided but i can't seem to find the info anywhere. Any help will be greatly appreciated Quote
JesperMP Posted August 2, 2005 Report Posted August 2, 2005 (edited) I have done it a couple of times on OP270 panels, and I am 99% certain that the MP370 works the same in this respect. To save or read to/from CF card: Insert a CF card in the slot in the rear. Exit to the Windows Control Panel on the MP370 (if in doubt, cycle power and when the panel powers up again then select "Control Panel" before the main application is started). The is a utility called "Backup/Restore from flash card" (going from memory here). Use "backup" to write to the CF card, and "restore" to read from CF card. If you need to update an MP370 in the field by sending a CF card in the mail, then you must load the application onto another MP370 (at home) and use the abovementioned utility to get the application onto the card. Edited August 2, 2005 by JesperMP Quote
