Mitsubishi memory card A2SNMCA-30KE
Guest Dejan Beljic
Hello, Does anyone know how can I install memory cassete A2SNMCA-30KE on Mitsubishi A2SH PLC? I am using GX IEC developer 6.01 and I dont know how to set proper parameters. Thanks, Dejan
Which parameters you have to set?? I think you don't need to set nothing, just to install memory device on the socket of cpu module. GX/GX_IEC automatically download/upload project onto AnS memory card. Bye Max
Guest Guest_Dejan
I need memory extension. My main program size is about 16k but memory card A2SNMCA-30KE has only 14k for main program. Can I load program from PLC's ROM and program from memory card (together) into PLC's RAM ?
With A2SHcpu you can not expand the memory. Memory card is used only for memorize the program, not to expand the memory. 14K is the maximum size of plc program. If you have a plc program with more than 14K you have to choose A2SHcpu-S1 that provide 30K of plc program max
