Have a look at this article (attatched) from the knowledge base. Maybe it applies to your problem. Otherwise, sign up to the Citect e-mail users list from Citect.com (you'll have to create an account). If you're a registered user you can also download the Knowledge base, it's very usefull with over 3000 of articles. Q4150.txt Edited by PdL
Thank you PdL for your help ! I read the attatched file, and i think the problem it´s for include one proyect off Citect in other. In may case, i´m start use Citect only want create a new proyect four taining. I use a demo version of Citect. I Create a New proyect and i don´t have a problem, but when execute the runtime no execute the Runtime of my new proyect, execute other proyect ( a demo proyect) How can i do to execute the Runtime of my new proyect ? I try something change parametres but appears the error that I have described to you previously. U read the manual of Citect but i can´t find any referencia about execute runtime. Thanks
Have you run the computer setup wizard already !? There is defined which project the computer will run. Does your project compile ok ? Edited by PdL
Hi Infoplc, Have you check if Include and CVS_Include is in your Citect Explorer? " The Include Project contains the original pre-defined elements from CitectHMI/SCADA prior to Version 5.50. These elements include keyboard key definitions, font definitions, genies, super genies and symbol libraries. The CSV_Include Project is a preconfigured project that is installed with CItectHMI/SCADA version 5.50 or later. The CSV_Include Project provides an updated set of these elements that can be used to create new projects based on Windows XP style". Quoted form Citect Basic Configuration Training Manual, Ver 6.00pg2-5. Sanif
Guest Guest
Hello ! The problem this resolute thanks! Now i tray to use a ActiveX ComboBox (Microsoft Forms). Somebody knows where i can find information o example of this ActiveX ComboBox ? Thanks !!!
