Siemens S7-315DP Run Status Bit
Guest Frazzled
So I do not have to spend an hour or so trying to find the information in the manuals or website. Does anyone know what bit or bits represent when a S7-315 DP PLC is in run mode? Thanks in advance!
Guest Guest
A PLC program is executed only when a PLC is running. So why would you need this bit for ?
Some PLCs do not let you tie outputs or commands directly to the left hand power rail in ladder. So you use an always on bit to put on the left of the instruction so it basically works the same as a horizontal line.
