alik Posted August 14, 2005 Report Posted August 14, 2005 Hi , I am using a wincc 5.1 for an s7/300 project . I reinstalled the software of wincc and now every time I open the project and try to activate it deactivates immediately . what could be the problem ? Is it an authorization problem ? thanks alik Quote
Guest Fritz_frederix Posted August 16, 2005 Report Posted August 16, 2005 Hi, What do you mean by activate? Normaly a WinnCC can work whitout the authorisation key for a limited of time. Rudi Quote
Guest JVL. Posted August 18, 2005 Report Posted August 18, 2005 Hy, I suggest you can have a problem with the WinCC program or with the Project. To find out were the problem is you can open a backup or a different project. When you have the same problem the WinCC program is not correct. You can check the computername in the project, possible this give's the problem. JVL. Quote
alik Posted August 20, 2005 Author Report Posted August 20, 2005 Thanks I solved that . I have another problem now but I will post with another subject Quote
