JuhaPK Posted August 15, 2005 Report Posted August 15, 2005 (edited) I have problem with WinCC flexible 2004 micro. When I try to transfer project to op, i get compiler error. Error say´s : "Error : Internal error (detail: [key=Index{Width=28, Height=28},id=8525202b-ff89-4356ac3a67f9d9a0e4d8]:Siemens.Simatic.Hmi.Utah. ES2RT.Smart1.Common.ES2RTCompilerException: unknown id 8525202b-ff89-4356-ac3a-67f9d9a0e4d8 at Siemens.Simatic.Hmi.Utah.ES2RT. Smart1.Linker.LinkerStore.GetObjectByRtId(Guid rtId) at Siemens.Simatic.Hmi.Utah.ES2RT.Smart1.Linker.LinkerStore.GetGuidValue(String key, Guid rtId))." I think it´s some problem with graphics that I use, but I don´t understand what. Everything works fine, until i restart WinCC. When i but some new graphics after restart, I get error. Edit: I try also some graphics (jpg) what i found from this sites, but same error again. So graphics is not problem, problem is in WinCC. My op is TP177 micro. Thanks for any help! Edited August 15, 2005 by JuhaPK Quote
JuhaPK Posted August 18, 2005 Author Report Posted August 18, 2005 (edited) Solution for this problem was "Compiler / Rebuild all". After that everything works fine. Edited August 18, 2005 by JuhaPK Quote
