Guest YC Posted August 20, 2005 Report Posted August 20, 2005 Hi.. How increase or speed up the scan time of PLC??? Thanks... Quote
gravitar Posted August 20, 2005 Report Posted August 20, 2005 Umm.. get a faster processor streamline/optimize your code I'm not sure there's a way other than the two listed above. As for SPECIFIC WAYS to perform the latter, you'd have to closely consider your specific program and how your machine uses it. Quote
larry818 Posted August 24, 2005 Report Posted August 24, 2005 If you've got some bit of code that's time critical, use an interrupt routine if your plc supports it. Quote
