If you are using a Q02 or higher, you could use special timer <STMR> for an OFF delay timer (page 6-119 in the Q programming manual). Any timing function you need to do (ON, OFF, ONE-SHOT, etc.) can always be done with a standard timer, although it will usually require a bit more code. Edited by mjrx
esgels, I hope this helps:    x0 ---l/l----------------[ T0 k10 ]    x0 ---l l-------+--------[ y0 ]    y0   T0    l ---l l---l/l--+ regards, paw
