Tank_Harvey Posted August 29, 2005 Report Posted August 29, 2005 We have just change some 90-70 PLC's to run on CME rather than Logic Master. Now under CME when we download a program change it seems to suspend communication all other devices and our change are within one block. This causes our Ethernet communication to fail to our other PLC's Has any other person found the same problems? Comments? Our distributor is suggesting an RX7i upgrade but that is easer said than done. Quote
Guest Guest_Russ Posted August 29, 2005 Report Posted August 29, 2005 If you have not done so yet, get Proficy ME (Cimplicity ME) Service Pack 3 and LD PLC Hot Fix 7. If these do not correct he problem, update your 90-70 Ethernet modules with the latest firmware. If this does not correct the problem check with GE Fanuc tech. support at support@gefanuc.com. You are right you should not need to upgrade to RX7i to fix this. However, the RX7i may give you other advantages. Quote
