alnaser Posted August 31, 2005 Report Posted August 31, 2005 I have a communication problem beetwen CxSupervisor and CxSimulator I started CxSimulator (Controller Link) ---------------------------------------------- <Target FINS address> Network address : 1 Node address : 10 Unit address : 0 --------------------------------------------- In CxSupervisor I added the new device (the same device type as device in CxSimulator) Network Type : (first try) Controller Link: Network 1, Node 10, Unit 0 (second try) FinsGateway : Network 1, Node 10, Unit 0 In "Point Editor" I added new variable "PLCvar1" whith "I/O attributes":PLC whith PLC Attributes: --------------------------------------------------- PLC type : the same type as PLC in cxsimulator Data Location : D00080 checked "Communication Enabled" Data Transfer Optimisations: "Always Update Point Value" ---------------------------------------------------- The problem is that my program is "Unable to open PLC ..." and I can't set value to "PLCvar1" please help Quote
BobB Posted September 1, 2005 Report Posted September 1, 2005 I thought CX-Simulator was for use with CX-Programmer, not CX-Supervisor. Quote
gtsuport Posted September 1, 2005 Report Posted September 1, 2005 Pretty sure Bob is right on this. I think CX-Simulator will only work with CX-Programmer and only to simulate CS1/CJ1 processors. Jay, can you verify that one for us? Quote
Guest anonymous Posted September 1, 2005 Report Posted September 1, 2005 Don't think it can work with CX-Supervisor - Supervisor uses CX-Server as the middleware, which CX-Simulator doesn't. Will post again if I discover otherwise! Regards anonymous Quote
Guest anonymous Posted September 1, 2005 Report Posted September 1, 2005 (edited) Sorry Guys, I'm lying through my teeth It IS possible to use the two together. Start CX-Simulator from the windows Start menu, select the required PLC type and use the default settings for Network Type. Network and Node addresses. (Controller Link, Network 1 Node 10 Unit 0). In the work CX-Simulator dialogue, Connect to the virtual PLC The virtual PLC must be started first, or CX-Supervisor will not be able to open the device. In CX-Supervisor, set the PLC / Network as per CX_Simulator. When the CX-Supervisor application is run, it should connect to the virtual PLC without problems. Regards anonymous Edited September 3, 2005 by anonymous Quote
