Guest Freddie Posted September 6, 2005 Report Posted September 6, 2005 Hi there, I need to read data from a Mitsubishi A2N series PLC using OPC. What OPC server can I use to help me do this? Quote
navillusi Posted September 6, 2005 Report Posted September 6, 2005 Any OPC driver using the A series protocol. You have a choice of connection methods, Serial to CPU or C24 card or Ethernet to Ethernet card are the most usual. Mitsubishi do the MCS OPC driver which will do all of their PLC's Others that are available would include Kepware or Beijers, there are lots available on the market. Quote
