Guest Guest_Solonel Posted September 12, 2005 Report Posted September 12, 2005 Hi, I use PCM711 port1 to communicate with Gefran 2308. I don't have any cabling info so i cannot achieve connection. What kind of cable should i make? I use RS485 protocol. Thanks, Solonas Quote
Steve Bailey Posted September 12, 2005 Report Posted September 12, 2005 Pinouts for the PCM ports can be found in the manual GFK-0255. Sorry, but I can't help you with the Gefran 2308. I don't know anything about that product. Quote
Guest Guest_Solonel Posted September 12, 2005 Report Posted September 12, 2005 Thanks, i' ll keep searching... Quote
PdL Posted September 12, 2005 Report Posted September 12, 2005 Google is your fwiend GEFRAN 2308 Multizone indicator / alarm unit Quote
