sirockin Posted September 14, 2005 Report Posted September 14, 2005 Hi all Does anyone know if it is possible to program the FX80MR PLC from any of Mitusbishi's PC based programming packages. If so: - which ones? - what interface cable do I need? if not: - what alternative methods are there? Thanks in advance, Dave Quote
hculyer Posted September 14, 2005 Report Posted September 14, 2005 Hello sirockin, You can use Medoc a dos based program to program from a pc. Here is a link for a download. http://www.plcman.co.uk/page6.html You will need an SC-09 programming cable. As an alternative you can try the programming cable Sergi posted on this forum. GX Developer will also work. Quote
