Guest datta jagtap Posted September 22, 2005 Report Posted September 22, 2005 Dear friends, I am working om one application where I am going to use a pl7 first time. I have some difficulties about PID instruction. that is : - How to call Pid instruction. - How to access the internal parametres like SP. KP, TI ,TD. etc. - Memory allocation My Resources are... - PL7 ( V4.3) - TSX 57203 - AEY1600 - ASY 800 Quote
undercontrol Posted September 26, 2005 Report Posted September 26, 2005 Are u the one who posted this on control.com?? Anyway, you could click on "Tools" then choose "Library" then it'll give you a new window opened with variations of function available like communication, math,.... also PID. For PID function, you choose "Process Control" on the left side window then it'll give you options for PID or PWM. For the parameter setting, you could adjust it through the window below. Hope, this helps!! Quote
