I need to modify an S5 system (CPU 102), I have uploaded the program from the processor and can both view and edit it offline. However when I try to edit it online I get the following message: OPERATION BLOCKED BY PRESETS OK, I'll edit it offline then download it to the processor, result is: OPERATION BLOCKED BY PRESETS I am presuming there is a method by which the processor can be "locked " to prevent the code being tampered with. Can anyone tell me if this is the case and point me in the right direction to overcome this problem. Many thanks
You ended up posting this in the Omron forum. I do not know how to move your post to the Seimens forum. You should repost you question in the Seimens forum.
Guest Guest_ratcliffe_ic
This problem was in Step 5 Version 6.6 Go to Projects > Settings > Page 2 and under the Mode setting select Allow Edits Note you must be connected to the processor to change this setting. Seems simple now, but the message was a bit misleading for a Siemens novice.
