WierdScience Posted September 26, 2005 Report Posted September 26, 2005 I'm putting together an update program for a laser marker part handler. It indexes around to present a freshly loaded part to the laser beam. It will look at diferent input combinations and output a fault code. Any body done this befor?? the key is to flash a certain amout then pause then flash another amount. I can figure it out BUT if anybody has already done this I will be verry gratefull for a head start. thanks David. Quote
bluebyu Posted September 27, 2005 Report Posted September 27, 2005 We have done that for years. It is easy to do and cheap. Over time, counting the flashing lite can become very annoying. We migrated to a counter, we would have the PLC increment the counter, and hence display the fault code. As of late, we only use HMI's. Either new small models costing 250$. Or better more functional models from E-Bay. Quote
