Guest Mr. Burg Posted September 27, 2005 Report Posted September 27, 2005 Currently working with a Modicon Momentum PLC (M1 960-30) & ProWorx 32 software. PLC runs OK in every respect: code, online changes, saving, communication on TCP/IP to Lpt & PanelMate. Every now & then the controller will be stopped, when I haven't clicked stop controller before going offline & closing ProWorx 32. Why / what would stop the controller? I know when you cycle power the controller should boot up & begin running. I have already transfered the program to EEPROM, anyone know why the controller would stop on its own? Thanx in advance... Quote
Crossbow Posted September 27, 2005 Report Posted September 27, 2005 There should be a stop code stored in the PLC's memory that you could read in Proworx to determine the reason it's stopped. Look at the PLC diagnostics in Proworx. Quote
