RhInO430 Posted September 27, 2005 Report Posted September 27, 2005 (edited) Alright who is the scholar out there. I have 12 load cells with 10 volt excitation and 4 LVDT's operating at 3 VAC and I need all of the analog data to be stored in the plc. I was planning on using a standard dual relay and analog out option on the LVDT signal conditioner/display. And taking a standard signal conditioner for the load cells and bringing in the analog data into the plc via an analog card. Basically all of the signals would come in through the analog inputs then all I have to do is store all of the info. How would you guys out there do this type of application. Edited September 27, 2005 by RhInO430 Quote
