serial output to erial printer siemens
Guest rafi
Hello I have siemens plc simatic s5 and the serial communication output direct to the printer. The printer is a siemens with serial module, the module of “TALLY” company type MT150/9, I wont connect a pc computer instead the printer. And save all messages in a file in the pc. Thank you very mach for help Rafi
I did the same some years ago. I used a programm called "Procom" and a serial cable from plc to the pc. The only thing you have to do is to make sure the "procom" settings of the rs232 are ok. Greetings Harry
