Guest J@ck Posted October 14, 2005 Report Posted October 14, 2005 Hi, I 've got problm with setting up a connection s7315 with intouch via MPI I set up everything in Simatic Net It works perfectly! (exchanges data with Simatic Net OPC Server) But the question is how to set up Intouch ? Shall I use DASS7 or FS gateway ? If YPU know please help... regards J@ck Quote
Guest Guest Posted October 14, 2005 Report Posted October 14, 2005 Ok. problem is solved There was a problem with path of DASS7 :) Quote
