Programming in ST (Structured Text)
Hi all, I am trying to the GX IEC Developer and are trying the ST programming mode. But how do you make a Pulse --|P|-- ?? Does any of you have any experience in the ST programming (good or bad)? Thank you Dariusch
Hi Rodney, The LDP instruction is for the IL or MELSEC IL, but I am using the ST programming mode. "IF THEN ELSE". What I really want to do is to increment a register for everey sec. like IF X0 AND M8013 THEN; D0 = D0+1; END_IF; But the above will increment for a hole sec. I need a pulse to onyl increment 1 for every sec. Dariusch
Hi all Now Iam so fare: Test_TRIG(_CLK:=Start); IF X3 AND ??? THEN; D12:= D12+1; END_IF But where is the output from the oneshot??? The Test_TRIG is the FB "R_TRIG" (IEC) and the variable for execute the FB is "Start" (_CLK) , but where is the (Q) output?? Dariusch
Ok I got the info for the FB The answer is Test_TRIG.Q where the "Q" is the output (oneshot) Dariusch
