Upgrade A0J2CPU
Guest Guest_Steve
Guest Guest_Steve
Hi All, I have problem in replace the A0J2CPU with A0J2HCPU. I have upload the ladder from the A0J2CPU. Then we convert it into A0J2H. The problem is: A0J2HCPU not work normaly. l mean there is a 7 segment display that display wrong data. Let say we input data 1, then the 7segment show 101. If we enter data 2, the display will show 202. I have change the parameter according to A0J2 old setting. There is some intruction using ENCO, DECO, SUM, Duty Cylce. Is it any problem in aply to new A0J2HCPU? But if we put down the A0J2 to the old system, the system work ok. We have re-check the ladder all the same. Anyone that have the same experience?
