Guest Norman Posted October 30, 2005 Report Posted October 30, 2005 I have a FX0n-24es I have attatched a 40er-es powered extention block,what are the outputs called on the extention block,it has three rows 0-7 I've tried y201 but Developer says invalid output do I need to tell the plc it has an extention on it if so how? Thanks Norman
navillusi Posted October 31, 2005 Report Posted October 31, 2005 The Fx0n 24 has 14 inputs and 10 outputs, inputs are X0 thru X15 and Y0 thru Y13, two bytes of I/O have been used. When an extension block is fitted, the IO continues from the next available IO byte, thus the outputs on your block will start at Y20 (Y20 thru Y47)
Guest Norman Posted October 31, 2005 Report Posted October 31, 2005 Ok thankyou thats sorted that out,can't see wood for the trees I think,but then it 's like that sometimes! Many Thanks Again Norman
