Is there a list or database of Siemens part numbers and the significance of the 4 or 5 letter suffix; e.g. what's the difference between 6ES5460-4UA12 and 6ES5460-4UA13? Or (as I suspect) do I have to contact Siemens in each case and hope for an answer at some point in the future?
Go to Siemens AD Mall, where you can search for (almost) anything. Unfortunately I noticed that your part numbers are for some old S5 parts. These are not always in the list of items (including your part numbers). So try also Siemens support where you also can search. Your two part numbers resulted in many hits. You will have to figure out yourself which ones that are relevant.
Guest Fritz_frederix
Hi, Here's what I've found about your question. You also could use this LINK for the Siemens search page. Rudi
