mmervenne Posted November 8, 2005 Report Posted November 8, 2005 Hello all. I am working on my first project with Mits. I was wondering if there was a way to test my E700 program with my PLC Program without having any hardware connected. I basically am just looking to simulate both. Any help is Greatly appreciated. Mike Quote
navillusi Posted November 8, 2005 Report Posted November 8, 2005 Yes and No! You can test the PLC logic by using GX Simulator which is an add on component of GX/GXIEC Developer, often referred to as Ladder Logic Test in the menu structure. As for the E700, the only way to test it is on the terminal, I do not know of a simulator for Beijers terminals. If you were using the latest model HMI's (the E1000 series) there is a test run / simulation package in-built within e-designer Quote
Guest Guest Posted November 9, 2005 Report Posted November 9, 2005 The only way to test a project on E700 terminal without plc, is to use the internal driver of E terminal. Bye Max Quote
