Guest CHARLES Posted November 9, 2005 Report Posted November 9, 2005 need help,please reply as soon as possible. i'm using tsx micro pl7. TQ.
Guest chandra Posted November 10, 2005 Report Posted November 10, 2005 hai, charles. did you mean you want to use analog input ? if it is true you can use operate at ladder diagram and you can fill with %mw0:=%iw5.1 for example. i hope it can help you much, you know ladder diagram to make between two plc communicate? i used tsx micro 37-21. if you know you can send some ladder in this forum. i have problem, you can see in this forum, maybe you can help me. thanx.Gbu
scada_vn Posted March 13, 2006 Report Posted March 13, 2006 I think when do input analog we should process in real format. ST: %MF1:=int_to_real(%iw3.0)
